PROBLEM
Maps printed or exported from ArcMap are bitmapped, scattered, banded, or display with low quality.
This happens for several reasons, independently or combined:
When exported or printed, ArcMap flattens and rasterizes the layer that is symbolized with either a picture fill, picture marker or transparency, and any layers beneath it in the Table Of Contents (TOC).
Other data frames in the map that do not contain picture fills, picture markers, or transparency are not affected.
It is highly recommended to use ArcGIS Pro for printing and exporting, especially when experiencing issues caused by the limitations of the ArcMap display engine. More specifically, ArcGIS Pro is not restricted by the graphical device interface (GDI) limitations that some users experience in ArcMap. For example, transparency is natively supported in ArcGIS Pro, preventing the rasterization of layers. Additionally, ArcGIS Pro supports transparency in layout elements. See Migrate from ArcMap to ArcGIS Pro for more information.
Note: ArcGIS Pro does not support exporting directly to AI (Adobe Illustrator) files as it is a closed file format. It is recommended to export to the AIX format and use the ArcGIS Maps For Adobe Creative Cloud extension in Adobe Illustrator to open the exported AIX files. For more information on the subtle differences between ArcMap and ArcGIS Pro in drawing, please see the help topic: Visual differences in imported map documents
If using ArcGIS Pro is not an option, use any of the following options below.
Article ID: 000002772
Get help from ArcGIS experts
Start chatting now
