PROBLEM
Map.Refresh in Mouse* events does not fire *LayerDraw events
Solution or Workaround
In Microsoft Access 2000, calling the Refresh and RefreshLayer methods in any of the Mouse* events will not trigger any of the *LayerDraw events.
Cause
This is a known issue.
Solution
Instead of using Map1.Refresh in the Mouse* event subroutine, try:
Code:
Dim rect as MapObjects2.Rectangle
Set rect = Map1.Extent
Set Map1.Extent = rect
This cannot be used to mimic the behavior of the RefreshLayer method.
Article ID:000001831
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
