PROBLEM
$Map profile variable missing when an Arcade expression is defined for pop-ups in the ArcGIS Enterprise portal
Last Published: July 22, 2025
The $map profile variable in the Arcade new expression window is missing, as shown in the image below.
map profile variable missing
The expected variable is as follows:
map profile variable available
Attempts to create an expression for pop-ups through manual input using the $map variable fail and return the Test execution error:
Error:
Compilation error - Line : x, y: Identifier not recognized. Verify test data.
Test execution error message
Cause
The expression is created on a map image layer (map service) instead of a hosted feature layer (feature service). While both map service and feature service are components that make up a web map, a map service focuses on displaying maps as images, while a feature service focuses on serving individual geographic features; points, lines, or polygons with their associated attributes, allowing for more dynamic and interactive experiences, including editing.
Map service is used to create pre-rendered maps, while feature service is for sharing and interacting with individual geographic features. So when creating an ArcGIS Arcade expression, the $map profile is excluded as interaction between different layers in the map, especially the FeatureSet function, is not possible.
Solution or Workaround
Use the expression on a hosted feature layer instead of a map service. For more information regarding feature services, map services and their capabilities, refer to ArcGIS Server: Feature services and ArcGIS Server: Map services.
Article ID: 000036935
Software:
  • Portal for ArcGIS
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
