PROBLEM
Map legend displays as carousel in the ArcGIS Instant Apps Basic (Media Map) template
First Published: January 19, 2026
Last Published: January 19, 2026
When viewing the map legend in the ArcGIS Instant Apps Basic (Media Map) template, it displays the legend items in a carousel. The legend displays only one item at a time, requiring multiple clicks to view all items. Because the carousel cycles endlessly without indicating the first or last item, it is difficult to identify the total number of legend items available, as shown in the horizontal legend below.
The legend displays as a slide in the ArcGIS Instant Apps Basic (Media Map) template
Cause
This is expected behavior. When the legend is enabled, the legend style is set to Card and the layout option is set to Auto, which applies the Stack layout. This configuration prioritizes a compact, mobile-friendly presentation but results in paginated slides when multiple legend items are present.
Solution or Workaround
To display the map legend in a non-carousel format, disable the Express mode and change the legend style.
  1. Log in to ArcGIS Instant Apps.
  2. On the Instant Apps home page, click the My Apps tab.
  3. Navigate to the app card and click Configure.
  4. In the configuration panel, toggle Express off to access the app's full setup mode.
  5. In the Turn off express mode window, click Continue.
  6. Click About > App details.
  7. Under Legend style, click Classic.
The configuration in the App details pane
The vertical legend below displays a scrollable list of legend items.
The legend displayed as a long, vertically scrollable list in the ArcGIS Instant Apps Basic (Media Map) template
Optionally, when using the Card legend style, change the layout option to display legend items horizontally within a single panel instead of across multiple panels. Under Layout option, expand the drop-down menu and select Side by side.
Article ID: 000039676
Software:
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
