PROBLEM
A map exported to PDF from ArcGIS 10 results in a larger file than one exported from ArcGIS 9.x.
Note: The content in this article pertains to ArcGIS versions 9.x and 10 only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
At ArcGIS 10, the default image stream compression for PDF was changed from 'Deflate' to the new 'Adaptive' compression option.
This reduces the default size of a PDF containing raster data such as orthophotography or other highly varied raster content.
However, for some maps that contain large areas of contiguous color that become rasterized, setting the image compression to 'Deflate' compression may actually result in a smaller output file.
Changing the image compression back to 'Deflate' for these maps results in PDF file sizes similar to ArcGIS 9.x.
Note: Maps containing highly varied raster imagery such as orthophotos result in smaller PDFs when using the 'Adaptive' or 'JPEG' compression options. Switch the compression back to 'Adaptive' or 'JPEG' when exporting these types of map content.
Article ID:000010990
Get help from ArcGIS experts
Download the Esri Support App
