PROBLEM
Magnifier window does not refresh on Citrix client
The magnifier window does not refresh or redraw automatically on a Citrix client with ArcMap 8.1.
Cause
This is an issue with ArcMap when published as a seamless application.
Solution or Workaround
  • Press the F5 key or click the ArcMap refresh button
    [O-Image] ArcMap refresh button
    to refresh the magnifier window in ArcMap.
  • Set Citrix to use the percent, pixel, or full screen display type.
  • Publish ArcMap as a non-seamless window.
Article ID:000002878
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
