PROBLEM
License Manager unable to read Options File
First Published: May 4, 2021
Last Published: August 5, 2025
When using an options file with ArcGIS License Manager, the license manager does not recognise the options file, and returns the following error message in the debug log:
Error: "(ARCGIS) CANNOT OPEN options file "=""
Cause
The service.txt file is configured incorrectly, and includes spaces in the 'PORT=<port_number>' parameter. This prompts the license manager to connect through an invalid port, as the port is incorrectly specified in the services.txt file.
Below is an example of the incorrect 'PORT=<port_number>' parameter with additional spaces:
[CODE BLOCK]: PORT = <port_number>
Below is an example of the correct parameter (no spaces):
[CODE BLOCK]: PORT=<port_number>
Solution or Workaround
  1. Navigate to C:\Program Files (x86)\ArcGIS\LicenseManager\bin, and open the services.txt file.
  2. Remove the spaces in the 'PORT=<port_number>' parameter. Save the file.
  3. Launch License Server Administrator. Click Re-read Licenses > Apply > OK.
Article ID: 000025364
Software:
  • Portal for ArcGIS
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
