PROBLEM
Layers in a map service full extent display as NaN
First Published: December 11, 2018
Last Published: December 9, 2025
Published map services result in NaN, 'Not a Number' as the FullExtent property. For example, the initial full extent is as follows:
XMin: -1.2517040322409505E7
YMin: 3946983.752765715
XMax: -1.2444192662924586E7
YMax: 3999198.926415506
Spatial Reference: 102100 (3857)
And the resulting full extent after publishing is displayed as follows:
XMin: NaN
YMin: NaN
XMax: NaN
YMax: NaN
Cause
The issue is caused by corrupted data or an incomplete publishing process.
Solution or Workaround
Select and apply any of the workarounds provided.
  1. Export the data to a file geodatabase. For more information, refer to ArcGIS Pro: Export data.
  2. In the Catalog pane, expand the exported file geodatabase, and copy the feature classes into the enterprise geodatabase.
  3. Register the enterprise geodatabase with ArcGIS Server. For more information, refer to ArcGIS Server: Register your data with ArcGIS Server using ArcGIS Pro.
  4. Publish a new map service to ArcGIS Server. Refer to ArcGIS Server: Map service for more information.
  • Alternatively, if the map service is consumed through ArcGIS Runtime SDK for .NET, the full extent can be extracted using the following script:
var table = await ShapefileTable.OpenAsync(@"C:\Users\jenn6286\Downloads\states_21basic\states.shp");
var features = await table.QueryAsync(new QueryFilter(){WhereClause= "1=1"});
if (features != null)
	Envelope fullExtent = GeometryEngine.Union(from f in features where f.Geometry != null select f.Geometry).Extent;
Article ID: 000018637
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Runtime SDK for NET
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
