PROBLEM
It takes a long time to open an Attribute Table of a Feature Class stored in ArcSDE using ArcMap.
If the Feature Class is not registered with the ArcSDE, then the SQL sent to the database contains an outer join to return records that are in the business table, but have NULL shapes. The outer join causes a full table scan of the business table.
To Register a Feature Class with the Geodatabase, refer to the ArcGIS Help topic: "Registering SDE layers and tables with the geodatabase".
Article ID:000006468
Get help from ArcGIS experts
Download the Esri Support App
