PROBLEM
Labels from imported from ArcView 3.x views are not associated with their layer
Labels that were automatically attached to themes in ArcView 3.x are not associated to any layer when the project is imported into ArcMap. All labels are placed in the active annotation target in ArcMap.
Cause
ArcView only has one graphics list per view document, where all imported graphics are placed. The graphic set object, which each theme has when graphics are attached to a theme, could not reliably be used to ensure all graphics were imported just once.
Solution or Workaround
There is no workaround for this issue.
Article ID:000002887
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
