PROBLEM
When rendering a raster using the Minimum-Maximum stretch type, and the Edit High/Low Values option is selected, the stretch values along the color ramp display only the highest and lowest values, even when more than two intervals are applied. The labels for interval values between the lowest and highest values for the raster do not appear.
This is a known limit. By default, the Edit High/Low Values option supports two labels (highest and lowest) when rendering a raster using the Minimum-Maximum stretch type.
Note: When using the Minimum-Maximum stretch type, this issue also occurs if the raster display statistics is set to From Current Display Extent in the Statistics drop-down list, even if the Edit High/Low Values option is not selected.
Follow the steps provided below as a workaround when using more than two intervals.
to import the saved raster layer's symbology settings to the original raster layer.
Note: This issue does not occur in ArcGIS Desktop 10.5.
Article ID: 000014403
Get help from ArcGIS experts
Start chatting now
