PROBLEM
Label tool does not label features when selection is overlapping existing annotation of another Layer
Any feature that is labled using the label tool near the annotation of an existing layer will not be labled but rather a Map tip box will appear.
Cause
Annotation stored in the Map Document is conflicting with the label tool.
Solution or Workaround
  1. Right click on the Data frame.
  2. Select Properities.
  3. Switch to the Annotation tab.
  4. Uncheck the annotation.
  5. Click Apply and OK.
  6. Label the features.
  7. Turn the annotation back on.
    As an alternative you can store the annotation in as a Geodatabase Annotation Feature Class. Turn off the Annotation Layer while you are labeling other features.
Article ID:000004725
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
