PROBLEM
Label strings returned from ArcInfo coverages are garbled
Strings returned from a MapLayer based on an ArcInfo coverage are garbled. This may occur when using LabelPlacer, LabelRenderer, or returning the Value of a string Field in the Recordset.
Cause
CodePage support in MapObjects LT 2.0 does not include coverages.
Solution or Workaround
This is a known limitation. Codepage support for coverages is planned for
Professional MapObjects 2.1. The solution at MapObjectsLT 2.0 is to convert the coverage to a shapefile.
Article ID:000001971
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
