PROBLEM
In the Map widget of ArcGIS Experience Builder, a label class may overlap another label class at different zoom levels, as shown in the image below. This may cause confusion in interpreting the map's geographic elements.
The visible range set for each label class when transitioning to different zoom levels does not have an interval.
Set intervals in the visible range between label classes in ArcGIS Online Map Viewer.
The image shows the label classes do not overlap in the Map widget in ArcGIS Experience Builder.
Note: Reload and preview the experience in ArcGIS Experience Builder to apply the changes in the Map widget.
Article ID: 000031827
Get help from ArcGIS experts
Start chatting now
