PROBLEM
Label classes overlap at different zoom levels in the ArcGIS Experience Builder Map widget
Last Published: February 2, 2024
In the Map widget of ArcGIS Experience Builder, a label class may overlap another label class at different zoom levels, as shown in the image below. This may cause confusion in interpreting the map's geographic elements.
Label classes overlapping with each other
Cause
The visible range set for each label class when transitioning to different zoom levels does not have an interval.
Solution or Workaround
Set intervals in the visible range between label classes in ArcGIS Online Map Viewer.
  1. In Map Viewer, open the map containing the label classes. Refer to ArcGIS Online: Apply labels and follow Steps 1 through 8.
  2. Adjust the Visible range slider to change the visible range for the first label class. In this example, the zoom level is set from Countries to Country.
The zoom level is set from Countries to Country
  1. Repeat Step 2 for the second label class. In this example, the zoom level is set from States to Counties.
The zoom level is set from States to Counties
  1. Click Save and open and click Save on the Contents (dark) toolbar to save the visible range setting of the map.
The image shows the label classes do not overlap in the Map widget in ArcGIS Experience Builder.
The label classes do not overlap
Reload and preview the experience in ArcGIS Experience Builder to apply the changes in the Map widget.
Article ID: 000031827
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
