PROBLEM
When exporting a KML file using the Map To KML or Layer To KML tool in ArcGIS Pro, the process completes successfully, and the output can be opened and used in ArcGIS Earth. However, the displayed map extent in ArcGIS Earth does not match the specified extent from the tool in ArcGIS Pro. The KML file appears misaligned (either shifted, incorrectly centered, or excessively zoomed out), resulting in a misleading visual representation of the intended map area.
The image below shows the map extent in ArcGIS Pro.
The image below shows the map extent of the KML file in ArcGIS Earth.
The Map To KML and Layer To KML tools do not honor the extent settings in ArcGIS Pro. This is a known issue, logged as a defect. Refer to BUG-000164274 and BUG-000166550 for more information.
Note: Remove the original or any unnecessary layers to prevent exporting unwanted data before exporting the map. This can achieved by right-clicking the desired layer in the Contents pane and selecting Remove.
Note: To download the latest version of ArcGIS Earth, refer to ArcGIS Earth: Download and install ArcGIS Earth for instructions.
The image below illustrates the correct map extent in ArcGIS Earth.
Article ID: 000036680
Get help from ArcGIS experts
Start chatting now
