PROBLEM
After installing MapObjects—Java 2.0, the JoView Plus, JoView, and Tutorial sample applications fail to start.
The most likely cause is that the Java Virtual Machine (JVM) being referenced by the application is located in a path directory that contains spaces. For example, if during installation an existing JVM was chosen to be used, it may have been located in C:\Program Files\Java\j2re1.4.1. The space in 'Program Files' would have caused the failure of the batch files used to start the sample applications.
Code:
REM Startup script for ESRI MapObjects JoView Plus
set MOJ20=C:\ESRI\MOJ20
CALL %MOJ20%\Scripts\MOJ_RUN com.esri.jvp.JoViewPlus jvp.jar
%MOJ20%\Samples\JoViewPlus C:\Program Files\Java\j2re1.4.1%MOJ20%
Code:
%MOJ20%\Samples\JoViewPlus C:\Progra~1\Java\j2re1.4.1%MOJ20%
Although this is the most likely scenario, the DOS path version may not be the same on all computers, and a different path location may have been used altogether. To determine the appropriate DOS version of the path, utilize the command prompt. Open a new command prompt window and change to the directory where the path contains a space. So, using the same example, navigate to the C directory since 'Program Files' is located there.
At the prompt, enter: dir /x. The output will appear as in this image:
The Program Files line has been highlighted in white. Notice the Progra~1 listed in the fifth column. This is the shortened DOS version of the pathname that should be replaced in the batch files as outlined earlier.
Article ID:000006525
Get help from ArcGIS experts
Download the Esri Support App
