PROBLEM
Invalid token error in ArcGIS Monitor when registering ArcGIS Server as a component
Last Published: May 6, 2024
When registering an ArcGIS Server as a component with ArcGIS Monitor 2023.3.1, the following error may be encountered, as shown in the image below:
Example:
An Error occurred while running the observer
Server machine
'https://machinename.domain.com:7443/arcgis/sharing/rest/community/self' returned an error. 'Invalid token'
error while attempting to register server component
Cause
This error may indicate that the credentials you are connecting with are not valid. Please, double-check your username and password, as well as the requirements to register ArcGIS Server as a component.
    Solution or Workaround
    It is important to note that the requirements to register ArcGIS Server as a component with ArcGIS Monitor depend on whether the server site is federated on unfederated:
    • For federated ArcGIS Server sites, you must provide credentials for the ArcGIS Server primary site administrator account to register the site.
    • For unfederated ArcGIS Server sites, you must provide credentials for an ArcGIS Server user account with the administrator role to register the site.
    Article ID: 000032002
    Software:
    • ArcGIS Monitor Server
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
