PROBLEM
When opening a project with CADRG and/or CIB extensions, ArcView returns the error: "Segmentation Violation"
When the CADRG and/or the CIB extensions are turned on, and any images referenced by the project have been moved, renamed, or deleted, the CADRG and CIB extensions cause a segmentation violation.
Warning:
Make a copy of the damaged .apr file under a different name. This backup copy may be needed to revert to if some of the edits do not work.
Dependencies:
"$AVEXT/adrg.avx\n$AVEXT/cadrg.avx\n$AVEXT/smap.avx
\n$AVEXT/arcpress.avx\n$AVEXT/spatial.avx\n"
(FN.9060
Path: "$AVEXT/cadrg.avx"
In the following steps you will uses the find tool to search the file for references to this object.
Dependencies: 9058
Dependencies: 9059
Dependencies: 9060
Dependencies: 9061
Dependencies: 9062
Dependencies: 9063
Dependencies: 9064
Dependencies: 9058
Dependencies: 9059
Dependencies: 9061
Dependencies: 9062
Dependencies: 9063
Dependencies: 9064
(FN.9059
Path: "$AVEXT/adrg.avx"
(FN.9060
(FN.9061
Path: "$AVEXT/stmap.avx"
(FN.9059
(FN.9061
Dependencies:
"$AVEXT/adrg.avx\n$AVEXT/cadrg.avx\n$AVEXT/smap.avx\n
Dependencies:
"$AVEXT/adrg.avx\n$AVEXT/smap.avx\n$AVEXT/arcpress.avx\n
Follow the same steps above to remove the CIB extension from a Project file. Search for "CIB" instead of "CADRG".
Article ID:000002576
Get help from ArcGIS experts
Download the Esri Support App
