PROBLEM
Introduction Panel and Custom Header edits are not saved in ArcGIS Instant Apps
First Published: April 24, 2023
Last Published: May 6, 2024
There is a known issue in ArcGIS Instant Apps that prevents saving edits when configuring certain text components of the application. This is scheduled to be fixed in the June 2023 update of ArcGIS Online.
Cause
Edits made with the rich text editor components are not saved when the reduced motion setting is disabled on the user's computer. The edits will be shown in the configuration panel but do not show in the app preview or launched app.
Most common areas this has been reported:
  • Introduction panel
  • Custom header
Solution or Workaround
To fix this issue, enable the Reduce motion (Mac) OR the Show animations (Windows) setting, if it is not turned on, enable it. These controls are shown in the next two images.
Mac setting
  1. Go to System Settings > Accessibility > Display.
  2. Check Reduce motion to enable it, as shown in the next image.
Reduce motion control is checked
Windows setting
  1. In Windows Settings, search for Show Animations in Windows.
  2. In the Display settings, turn the Show Animations in Windows slider to On., as shown in the next image.
Show Animations in Windows is On
Article ID: 000030352
Software:
  • ArcGIS Pro
  • ArcGIS Online
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
