PROBLEM
Intermittent timeout issues when working with hosted feature services in ArcGIS Pro
First Published: February 3, 2025
Last Published: February 3, 2025
The attempts to save edits, load tables, or edit hosted feature services in ArcGIS Pro intermittently fail. These intermittent issues prevent local edits from synchronizing successfully with the feature service, affecting operations within ArcGIS Online or the ArcGIS Enterprise portal.
In some instances, the following error returns:
Error:
General function failure [Error code: 1000. Description: Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding. Operation canceled by user.. ]
Cause
The network timeout setting is not configured in the Registry Editor. Therefore, the system does not have a predefined duration to wait for a response from the remote server or service before timing out. Without the configuration, the default timeout behavior is applied, which is insufficient for environments with slow or intermittent network connections. This leads to errors or failed operations when interacting with remote services such as hosted feature services in ArcGIS Pro.
Solution or Workaround
The following steps involve making changes to the Windows Registry on one or more network machines and require administrative access.
Warning:
The instructions below include making changes to essential parts of the operating system. Esri recommends backing up the operating system and files, including the registry, before proceeding.
Esri cannot guarantee results from incorrect modifications while following these instructions. Exercise caution. Consult a qualified computer systems professional if necessary.
  1. On the Windows taskbar, click Start Start and type Registry Editor in the search box.
  2. Right-click Registry Editor and click Run as administrator. When prompted, click Yes in the User Account Control window.
Registry Editor in Windows
  1. In the Registry Editor window, navigate to the following registry hive:
\HKEY_CURRENT_USER\SOFTWARE\ESRI\ArcGISPro\Settings
  1. Right-click the window and select New > DWORD (32-bit) Value.
The DWORD (32-bit) Value option
  1. Specify a name for the value. Right-click the newly created value and select Rename to rename the value. In this example, the entry is named 'NetworkTimeout'.
The newly created value
  1. Right-click the new entry and select Modify….
The renamed entry
  1. Configure the parameters in the Edit DWORD (32-bit) Value dialog box.
    1. For Base, select Decimal.
    2. For Value data, type 600.
    3. Click OK.
Parameters in the Edit DWORD (32-bit) Value dialog box
  1. Reboot the machine to apply the changes. Refer to Microsoft Support: Restart (reboot) your PC for instructions.
Article ID: 000034490
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
