PROBLEM
Ink from Markup tools disappear after drawn in the data frame
Ink from Markup tools disappear after drawn in the data frame.
Cause
The Markup functionality is stored to the active annotation layer in the map document. If the map document has the default annotation group turned off, the ink is not visible.
Solution or Workaround
Turn on the default annotation and republish the map.
  1. In the ArcMap Table of Contents, right-click on the Data Frame and select Properties.
  2. Select the Annotation Groups tab and click on the Default Annotation group check box.
  3. Republish the map.
Article ID:000009294
Software:
  • ArcReader 9 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
