PROBLEM
INFO is not listed as an export file type in ArcView
When I export a table in ArcView, I don't see INFO as an output file type in either ArcCatalog or ArcMap.
Cause
INFO files can be read, but not created using an ArcView license.
Solution or Workaround
There are two possible solutions:
  • Use an ArcInfo or ArcEditor license. INFO data can be created, edited and deleted with either of these licenses.
  • Export your data to a different tabular format such as dBASE or Text file.
Article ID:000002956
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
