PROBLEM
In ArcGIS Experience Builder, the Chart widget returns an incorrect statistic value when the ‘View for empty selection’ option is enabled in the Data panel. The image below shows the web experience displaying the Chart widget with incorrect sum statistics for the selected field. This behavior can be observed when the data view is set to ‘Selected features’ on the Chart widget.
The default value of the 'Page size' setting on the Records tab in the 'View for empty selection' window is 100. However, this value is smaller than the result features. Therefore, the total number of result features in the widget is limited because the Chart widget does not support pagination. Refer to ArcGIS Experience Builder: Data source views for more information.
To resolve this issue, specify the 'Page size' setting to a value greater than 100.
Note: Several attempts to specify the correct page size are necessary to ensure the results are displayed in the connected widgets.
The image below shows the web experience displaying the Chart widget with the correct sum statistics for the selected field.
Article ID: 000033942
Get help from ArcGIS experts
Start chatting now
