PROBLEM
Incorrect number values returned via an OLE DB connection to an Oracle database
When a connection to an Oracle database is made using the Oracle 8.1.7 OLE DB provider, the content of all numerical fields display as zero in ArcGIS applications.
Cause
This is a known issue with the Oracle 8.1.7 OLE DB provider.
Solution or Workaround
Use the Oracle 8.1.7 ODBC driver or the Oracle 8.1.6 OLE DB provider to make the connection to the database.
Article ID:000004682
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
