PROBLEM
Incorrect field order in exported files from the ArcGIS Instant Apps Public Notification template
First Published: February 6, 2026
Last Published: May 15, 2026
In the ArcGIS Instant Apps Public Notification template, fields configured for display in a Map Viewer pop-up do not retain their defined order when they are exported as PDF or CSV files. The pop-up configuration panel below shows the fields list with the defined order.
The pop-up configuration panel with the defined order of the fields list
The PDF below demonstrates the mismatch between the field order and the defined order of the fields list.
Incorrect field order of the fields list in the PDF file
Cause
ArcGIS Instant Apps Public Notification exports use the input layer’s published field order when the pop-up is configured with a 'Fields list' element instead of preserving the field order defined in the Map Viewer pop-up configuration, resulting in reordered fields in CSV and PDF exports.
Solution or Workaround
  1. In Map Viewer, on the Contents (dark) toolbar, click Layers and select the feature layer.
  2. On the Settings (light) toolbar, click Pop-ups The Pop-ups icon.
  3. In the Pop-ups pane, next to the existing Fields list element, click Options The Options icon > Delete.
  4. Add the Text element to the pop-up configuration. Refer to Steps 2 through 5 foiund in ArcGIS Online: Add text for instructions. In Step 3, click Fields List {} and select the fields in the correct order.
  5. On the Contents (dark) toolbar, click Create app > Instant Apps. Configure the necessary information for the Public Notification template, and export it as a PDF or CSV file.
The PDF below shows the list of fields in the correct order.
Correct field order of the fields list in the PDF file
Article ID: 000040188
Software:
  • ArcGIS Online
  • Configurable Web Apps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
