ERROR
When conducting the Remote ArcIMS Manager installation or the ArcIMS Viewer installation using iPlanet web server, I receive the following message "Problem in opening a connection to the installer on the server. It is possible that the installer cannot be found or has a different name." What should I do?
If you use iPlanet, you need to make a change in the configuration of the MIME type property. The MIME type file tells the web server what to do when an incoming request is looking for a particular file extension. The Remote ArcIMS Manager installation requests Manager.exe, and the MIME type for the .exe extension needs to be edited so the web server can handle files with this extension correctly.
Article ID:000003902
Get help from ArcGIS experts
Download the Esri Support App
