PROBLEM
If AutoCAD Map 2007 3D is installed after ArcGIS Desktop, unable to preview shapefiles in ArcCatalog nor view them in ArcMap
**Internal Publish Only! This article may contain information that is not intended for external circulation.**If AutoCAD Map 2007 3D is installed after ArcGIS Desktop 9.2, the user cannot preview shapefiles in ArcCatalog nor add shapefiles to ArcMap.
Cause
There is a software conflict between ArcGIS Desktop 9.2 and AutoCAD Map 2007 3D.
Solution or Workaround
The solution is to do a complete uninstall of ArcGIS Desktop 9.2 and then reinstall on top of AutoCAD Map 2007 3D.
    Article ID:000009263
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
