PROBLEM
Hyperlinks not enabled in an ArcIMS HTML website
Hyperlinks are not enabled in an ArcIMS HTML website.
Cause
The hyperlink array is not correct in the ArcIMSparams.js file.
Solution or Workaround
  1. Add the correct hyperlink array in the ArcIMSparams.js file.
  2. Uncomment the following in the ArcIMSparams.js file:
    Code:
    // parameters for setting up hyperlinks in data display
    var hyperLinkLayers = new Array(); // layers to have hyperlink
    var hyperLinkFields = new Array(); // field in those layers to be used for hyperlink
    var hyperLinkPrefix = new Array(); // prefix (if any) to place before field value to make hyperlink url
    var hyperLinkSuffix = new Array(); // suffix (if any) to place after field value to make hyperlink url
    hyperlinkLayers[0] = "Parcels";
    hyperlinkFields[0] = "QUICKREFID";
    hyperlinkPrefix[0] = "http://www.zephyr.com/Appraisal/PublicAccess/PropertyDetail.aspx?PropertyID=&dbkeyAuth=Appraisal&TaxYear=2005&NodeID=11&PropertyOwnerID=";
    hyperlinkSuffix[0] = "";
    Remove the comments and save the file:
    Code:
    hyperlinkPrefix[0] = "http://www.zephyr.com/Appraisal/PublicAccess/PropertyDeatail.aspx?PropertyID=&dbkeyAuth=Appraisal&TaxYear=2005&NodeID=11&PropertyOwnerID=";
Article ID:000007875
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
