PROBLEM
Hyperlinks don't work for some XY data source layers and route event layers
Adding a hyperlink to some XY data source or route event layers will result in the link not being saved and the hyperlink tool will not work.
Cause
Manual hyperlinks are not supported by layers based on non-OID tables (tables without an FID or OID field). While ArcMap will let you add a link to features in these layers, the links will not be saved.
Affected layers include XY data source layers and route event layers based on:
¤ Text (.txt) files
¤ OLE DB tables (external database)
¤ Non-registered tables in a Geodatabase (includes Access and SDE type Geodatabases)
¤ SDE 3 tables
Solution or Workaround
Try one of these two workarounds:
  • Though manual hyperlinks are not supported for layers based on non-OID tables, these layers do support field-based hyperlinks:
    1. Add a new field to your table.
    2. Populate the field with hyperlink text.
    3. In ArcMap, create a layer from this table (for example, XY layer).
    4. Turn on field-based hyperlinks for the layer (Display tab on Layer Properties dialog box).
  • Export data to a format that supports manual hyperlinks.
Article ID:000002865
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
