PROBLEM
HTTP Error 500 Internal Server Error is returned when accessing Portal for ArcGIS and ArcGIS Server Web Adaptors
Last Published: September 29, 2021
When accessing Portal for ArcGIS or ArcGIS Server through the ArcGIS Web Adaptor URLs, with the web adaptors configured on virtual directories, the following error is returned:
Error:
The HTTP Internal Server Error response code indicates that an unexpected condition is preventing the connection between the server and the requested page.
Cause
The virtual directory that is hosting the web adaptor has credentials assigned. These credentials do not match the ArcGIS Server account credentials.
Solution or Workaround
Use the steps below to update the Microsoft IIS Virtual Directory credentials to match the ArcGIS Server account credentials.
  1. Open IIS Manager.
    1. On the Start screen, click Control Panel.
    2. Click System and Security and click Administrative Tools.
    3. In the Administrative Tools window, double-click Internet Information Services (IIS) Manager.
  2. Edit the Virtual Directory credentials. Refer to Microsoft: How to create a new Virtual Directory.
The workflow presented here requires the assistance of the organization's IT department.
Article ID: 000025312
Software:
  • Portal for ArcGIS
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
