PROBLEM
Grid function output cells misaligned when inputs have different cell sizes
Grid function output cells are misaligned when compared to the input grids when some of the inputs have different cell sizes.
Cause
All input grids do not have the same cellsize. If all the inputs do not have the same cell size and the default SETCELL value is used, Grid function output will default to the cell resolution of the coarsest input grid.
Solution or Workaround
Use the RESAMPLE function to create input grids with matching cellsize.
Code:
ingrd3_res = resample(ingrd3, <cellsize>)
You can use the DESCRIBE command to verify the input grids' cellsizes.
Article ID:000002122
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
