PROBLEM
Greenish cloud or haze when printing aerial images and data
There is a greenish cloud or haze in the printout when printing a map with aerial photo in it.
Cause
HP Technical Support confirm this issue. There is a problem printing a map with aerial photo to HP printers when using a High Glossy Photo paper. It was tested using an HP Designjet 4000, but may affect other printers as well. Because it is a problem with the printer, it does not matter if the map was printed through ArcMap or any other application, such as Acrobat Reader.
Solution or Workaround
Use a paper based media, such as common bond paper or HP coated paper.
Article ID:000008802
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
