PROBLEM
Getting a red X instead of the map image
In HTML viewers, the page appears to load, but instead of seeing the map, a red X appears.
Cause
The Map Service used in the HTML viewer has the Server Output URL Location pointing to a path that is not resolvable from the client. The red X in the browser window is an indication that the path to the image is incorrect.
Solution or Workaround
  • In either ArcIMS Manager or Stand-alone Administrator, open the property sheet for the service being used by this page.
  • Change the value of the Server Output URL location to be correct from the clients perspective.
  • On Apache Web servers, depending on the set up of the output virtual directory, it may be necessary to place an ending '/', for example:
    http://mymachine/output/
Article ID:000002017
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
