PROBLEM
Geoprocessing Wizard fails without error when merging PolylineM shapefiles
When trying to merge PolylineM themes, the Geoprocessing Wizard completes half of the operation and then stops.
Cause
Creating and editing PolylineM shapefiles is not supported through the core interface of ArcView. Therefore the Geoprocessing Wizard will not merge PolylineM themes.
Solution or Workaround
  1. Convert the PolylineM shapefiles to Polyline shapefiles. Use the sample xyz2xy.ave script provided in $AVHOME/samples/scripts directory.
  2. Merge the resulting Polyline shapefiles. Use the Geoprocessing Wizard to do this.
    Warning:
    The resulting Polyline shapefile will not contain the measurement information.
Article ID:000002138
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
