PROBLEM
Geodatabase annotation feature class contains an invalid item that cannot be deleted
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
An annotation feature class contains a text item with a width of approximately 2.1 billion that cannot be deleted.
Cause
This is a problem caused by a third-party software called ICOMAP.
Solution or Workaround
  1. In ArcCatalog, right-click the annotation feature class and select Export > Geodatabase to Coverage.
  2. Enter an output coverage and subclass name.
  3. Click OK.
  4. Right-click the new coverage annotation feature class and select Properties.
  5. Click the Items tab.
  6. Highlight the invalid item and click the Delete button.
  7. Click Apply and click OK.
  8. Convert the coverage annotation to geodatabase annotation using the 'Convert Coverage Annotation' tool in ArcMap. Instructions for performing this conversion can be found in the ArcGIS help under Contents tab > Geodatabases > Managing Annotation > Converting coverage and SDE 3 annotation to geodatabase annotation.
Article ID:000006605
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
