PROBLEM
Gaps are displayed on the 3D layer in ArcGIS Pro
First Published: August 3, 2023
Last Published: June 8, 2026
The 3D multipatch features display gaps or holes in a scene. This behavior is reproducible in both local and global scenes.
The 3D multipatch features with gaps and holes in between.
Cause
The surface of the multipatch feature is lower than the elevation of the surface layer, causing the surface to display gaps in the scene. Unlike a 2D map, the ground elevation surface in a scene contains z-coordinates that can be observed by hovering the cursor over the different surfaces and identifying the third value from the bottom of the window. The third value represents the height relative to the flat plane, and when the height of the surface is higher than the z-value of the feature, the ground surface elevation is overlaid with the feature.
The 2D map with no z-value at the bottom of the window pane.
The 3D scene with the z-value at the bottom of the window pane.
Solution or Workaround
Disable the ground elevation surface layer
Uncheck the ground layer check box in the Contents pane. Refer to ArcGIS Pro: Enable or disable layer editability in a map for more information.
The ground layer check box unchecked in the Contents pane.
The map below shows the 3D multipatch features displayed with no holes and gaps.
The 3D multipatch features with no gaps.
Increase the depth of the 3D multipatch feature
While editing the 3D multipatch feature, raise the depth of the multipatch feature above the elevation surface layer, as shown in the map below. Refer to ArcGIS Pro: Add a face for further instructions.
The depth of the 3D multipatch features increased above the surface elevation.
Article ID: 000030887
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
