PROBLEM
Flex Builder reports a problem about awx:Map
When using ArcWeb Explorer Flex API, Flex Builder reports the following problem:
"Could not resolve <awx:Map> to a component implementation".
Cause
Flex Builder cannot find the ArcWeb Explorer SWC file (where awx:Map is defined).
Solution or Workaround
Use one of the following solutions:
Put the SWC file in the root folder of the application (the MXML file being worked on) as instructed in Getting started with ArcWeb Explorer Flex API, step 4.
OR
Specify the library path in Flex Builder. To do this:
a. Right-click the project.
b. Select Properties.
c. Select Flex Build Path on the left side.
d. Select the Library Path tab.
e. Add a specific SWC using the Add SWC button, or use the Add SWC Folder option to add all SWC files in a specific folder.
f. Set the output folder URL. This must be an HTTP path to your Web server.
Article ID:000009743
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
