PROBLEM
Some temporary files are not being removed after some Spatial Analyst functions complete processing.
This is a known issue with ArcGIS 8.1.
The following files will not be removed:
· The INFO file generated by the Zonal Statistics function.
· The scratch table generated by the Histogram tool.
· Temporary shapefiles that get created when performing certain tasks, such as during projection, format conversion, or selection.
A regular cleanup of your working directory will alleviate this problem. Always remove ESRI grids with ArcCatalog or ArcInfo Workstation in order to remove the associated INFO files.
Article ID:000003329
Get help from ArcGIS experts
Download the Esri Support App
