PROBLEM
Fields are not displayed in ArcGIS Field Maps
Last Published: November 24, 2022
When viewing the features in ArcGIS Field Maps, some fields are not displayed, as shown in the image below.
The field values not available in the ArcGIS Field Maps web map.
Cause
The field or attribute expression is not selected in the Pop-ups pane.
Solution or Workaround
  1. Select the fields in ArcGIS Online Map Viewer.
    1. Log in to ArcGIS Online and click Content > My Content.
    2. Browse to the web map, click More Options The More Options icon. and select Open in Map Viewer.
    3. On the Contents (dark) toolbar to the left of the page, click Layers The Layers icon..
    4. In the Layers pane, click the layer.
    5. On the Settings (light) toolbar to the right of the page, click Pop-ups The Pop-ups icon..
    6. In the Pop-ups pane, under Options, click Fields list and click Select fields.
The Fields list and Select fields button in the Pop-ups pane.
  1. In the Select fields pane, check the relevant fields or expressions, and click Done.
The field values in the Select fields pane.
  1. Click Save and open The Save and open icon. > Save.
  1. Reload the web map in ArcGIS Field Maps.
    1. Log in to the ArcGIS Field Maps app.
    2. In the Maps list, browse to the web map and tap the Overflow menu The Overflow menu icon..
    3. Tap Reload Map.
The image below shows the features displayed in ArcGIS Field Maps.
The field values available in the ArcGIS Field Maps web map.
Article ID: 000028731
Software:
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
