PROBLEM
Field values with formulas in .xls files appear as nulls in ArcGIS Pro
Table fields in Microsoft Excel (.xls) files added in ArcGIS Pro display nulls if the fields are formatted with certain formulas. However, the same table displays field values in ArcMap.
Cause
This issue may occur due to unsupported field types used for formulas in the Microsoft Excel document. The field type specified in the Microsoft Excel table does not determine the field type used in ArcGIS Pro. ArcGIS Pro uses Geospatial Data Abstraction Library (GDAL) drivers and the supporting OGR Vector Formats to read Excel files. When a Microsoft Excel table is added to ArcGIS Pro, GDAL determines the field type used. Formulas that are not supported by the field type in ArcGIS Pro appear as null values in the attribute table.
Solution or Workaround
Select one of the options below to display the field values in ArcGIS Pro.
  • Save the .xls document into another format such as .xlsx or .csv before adding it to ArcGIS Pro.
  • Copy and paste all the fields into a new Microsoft Excel document, and use computed values for the fields instead of formulas before adding it to ArcGIS Pro.
Article ID: 000016367
Software:
  • ArcGIS Pro
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
