PROBLEM
Field value mismatch between attribute table and attribute pane in ArcGIS Pro
First Published: May 9, 2025
Last Published: September 10, 2025
In ArcGIS Pro, when opening the attribute table and attribute pane of a feature layer, different values are displayed for the same field.
Cause
This issue occurs due to an unsuitable rendering engine setup. When the rendering engine is incompatible or misconfigured, it can lead to display glitches or data not refreshing properly across panes.
Solution or Workaround
To resolve the issue, apply the following steps to change the rendering engine to OpenGL.
  1. Open the ArcGIS Pro project.
  2. On the ribbon tab, click the Project tab and click Options.
  3. In the Options dialog box, click Display.
  4. In the Rendering engine section, click OpenGL.
  5. Click OK.
  1. Close and reopen the project.
Article ID: 000036063
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
