PROBLEM
Field names are truncated to ten characters in ArcMap and ArcGIS Pro when exporting shapefiles from ArcGIS Online
In ArcGIS Online, hosted feature layers can be exported in various formats. However, when exporting as shapefiles, field names exceeding ten characters are truncated to only ten characters. For example, ‘City in California,’ ‘Latitude of City,’ and ‘Longitude of City’ are truncated to ‘City_in_Ca,’ ‘Latitude_o’, and ‘Longitude_o’, respectively. The image below shows the truncated field names when a shapefile is exported from ArcGIS Online and opened in ArcGIS Pro.
The truncated field names
Cause
This is a known limitation for shapefiles. Shapefiles use the dBASE file format to store attribute information of features, which imposes a ten-character limitation for field names. Refer to the following resources for more information on exporting shapefiles:
Solution or Workaround
Choose either one of the methods below to display field names with more than ten characters.
Create an alias for field names exceeding ten characters in ArcMap or ArcGIS Pro
  1. In ArcMap or ArcGIS Pro, open the exported shapefile. In this example, it is opened in ArcGIS Pro.
  2. Open the attribute table, and right-click a truncated field name. Click Fields, and the Fields view opens.
The attribute table
  1. In the Alias column, double-click to rename the truncated field names with the desired names. In this example, the alias of the truncated field name is changed to City in California. Refer to ArcGIS Pro: Create and manage fields and ArcMap: Setting field aliases in tables for more information on altering field aliases.
The Field view
In ArcMap, right-click the truncated field names, and click Properties. Rename in the Alias column.
The Field Properties window
  1. Click Save on the Feature Layer tab of the Menu pane. Navigate to the layer's attribute table. The field name is not truncated.
The field name is not truncated in ArcGIS Pro.
Export the hosted feature layer as a file geodatabase (FGDB) from ArcGIS Online
  1. In ArcGIS Online, open the item details page of the hosted feature layer to export. On the Overview tab, click Export Data > Export to FGDB.
The Overview tab.
  1. In the Export to File Geodatabase window, fill in the required information. Click Export.
The Export to File Geodatabase window.
  1. Once the export is complete, navigate to the folder containing the exported FGDB, and open the item details page. Click Download, and save the exported FGDB.
The item details.
  1. Open the FGDB in ArcMap or ArcGIS Pro and view the attribute table. In this example, it is opened in ArcGIS Pro.
The image below shows field names with more than ten characters are not truncated.
The field names not truncated
Article ID: 000022868
Software:
  • ArcMap
  • ArcGIS Online
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
