PROBLEM
Field names appear different when exporting a joined layer to a shapefile
First Published: June 15, 2018
When exporting a joined layer to a shapefile in ArcGIS Pro, the field names in the attribute table of the shapefile appear differently than the joined layer.
Cause
In ArcGIS Pro, the Copy Features geoprocessing tool uses the Qualified Field Name environment setting by default when exporting a joined layer. Qualified field names have the name of the origin feature class or table appended to the field name. The default structure of the qualified field name is tableName.fieldName. For example, a table named Customer with a field named CustID would have a qualified field name appearing as Customer_CustID.
Solution or Workaround
To omit the feature class or table name of the joined layer when exporting to a shapefile, the Qualified Field Name environment setting must be disabled. The following steps describe how to disable the Qualified Field Name environment setting in the Copy Features tool:
  1. Search for and open the Copy Features tool in the Geoprocessing pane.
  2. After specifying the Input Features and the Output Feature Class on the Parameters tab, click the Environments tab.
  3. Uncheck Maintain fully qualified field names to remove the table name.
    Screenshot of Copy Features with Maintain fully qualified field names unchecked.
  4. Click Run to export the joined layer.
Article ID: 000018337
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
