PROBLEM
Field aliases do not show in the chart symbology method's normalization combo box
If you have Bar/Column or Stacked Chart symbology, the field alias for the normalization field does not appear in the combo box or in the Table of Contents. Only the field name appears.
Cause
This is a known issue at the 8.1 release.
Solution or Workaround
Edit the label in the Table of Contents by clicking it and manually entering the field alias.
This was fixed at version 8.1.2.
Article ID:000002845
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
