PROBLEM
Features not displayed in ArcGIS Field Maps
First Published: April 1, 2024
Last Published: March 13, 2026
When opening a web map in ArcGIS Field Maps, certain features are not displayed.
Cause
The hosted feature layer includes field data types that are not supported in Field Maps, such as big integer, date only, time only, and timestamp offset.
Solution or Workaround
Change the field data type to one that is supported in Field Maps. In this case, the date only data type is changed to the date data type.
  1. Open the ArcGIS Pro project.
  2. Add a new field to the feature layer with the preferred field type and use the Calculate Field tool to populate the values of the new field with values from the original field. Refer to How To: Change the data type of an existing field in ArcGIS Pro for instructions.
The Fields table in ArcGIS Pro.
  1. Right-click the original field and click Delete.
  1. Overwrite the web feature layer. Refer to ArcGIS Pro: Overwrite a web feature layer for instructions.
  2. Add the hosted feature layer to a web map in ArcGIS Online.
    1. Log in to ArcGIS Online.
    2. Click Content > My Content.
    3. Browse to the hosted feature layer, click More options, and click Open in Map Viewer.
    4. Save the web map. Refer to ArcGIS Online: Save maps for instructions.
Article ID: 000032230
Software:
  • ArcGIS Pro
  • ArcGIS Field Maps Android
  • ArcGIS Field Maps iOS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
