PROBLEM
Features are not listed in the Create Features pane in ArcGIS Pro
Last Published: January 25, 2024
In ArcGIS Pro, when creating shapefiles or feature classes in an editable layer, the features are missing from the Create Features pane and the following error is returned.
Error:
No editable layers
No editable layers.
Cause
The shapefiles or feature classes contain an unknown coordinate system.
Solution or Workaround
The following workflows are applicable to both shapefiles and feature classes.
Create new shapefiles or feature classes and specify a coordinate system
  1. Open the ArcGIS Pro project.
  2. On the ribbon, click Analysis and click Tools.
  3. In the Geoprocessing pane, search for and click the Create Feature Class (Data Management) tool.
  4. In the Create Feature Class pane, specify a geodatabase or folder in which the output feature is created.
  5. For the Feature Class Name parameter, specify a name for the feature.
  6. For the Coordinate System parameter, click the Select coordinate system icon or select Current Map [Map] from the drop-down menu to specify the desired coordinate system.
  7. Click Run.
Create Feature Class parameters
Create a copy of the feature classes or shapefiles with a defined coordinate system
  2. In the Contents pane, right-click the feature layer.
  3. Click Data > Export Features.
Export feature from Contents pane
  1. In the Export Features window, click the the Environments tab.
  2. For the Output Coordinate System parameter, click the Select coordinate system icon or select Current Map [Map] from the drop-down menu to specify the desired coordinate system.
  3. Click OK.
Overwrite the coordinate system information of the existing feature classes or shapefiles
  3. Search for and click the Define Projection (Data Management) tool.
  4. For the Input Dataset or Feature Class parameter, select the original feature class or shapefile with the unknown coordinate system.
  5. For the Coordinate System parameter click the Select coordinate system icon or select Current Map [Map] from the drop-down menu to specify the desired coordinate system.
  6. Click Run.
Adding coordinate system in the input geodataset
Article ID: 000031666
Software:
  • ArcGIS Pro 3 1
  • ArcGIS Pro 3 0
  • ArcGIS Pro 3 2
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
