PROBLEM
Feature selection is not honored in the ArcGIS Experience Builder Analysis widget
First Published: January 8, 2026
Last Published: February 19, 2026
In ArcGIS Experience Builder, the Analysis widget includes all features in the input layer for a spatial analysis tool, ignoring feature selection from a connected widget, as demonstrated in the Map and Analysis widgets below.
The Analysis widget includes all features instead of the selected features
This issue also occurs in other widgets used for feature selection.
Cause
The Analysis widget currently does not support feature selection from connected widgets as the input source, so it does not automatically filter or limit the input based on the selected features.
Solution or Workaround
Ensure the Set as Analysis input data action is checked under Data action on the Action tab of the connected widgets before configuring the data action for the selected features.
Use the Select widget
  1. Open the ArcGIS Experience Builder web experience for editing. Refresh the web experience, if necessary.
  2. Navigate to the Insert widget panel.
  3. On the New tab, under the Data centric group, drag and drop the Select widget onto the canvas. Configure the parameters for the Select widget. Refer to ArcGIS Experience Builder: Settings for more information.
  4. On the builder toolbar, click Live view.
  5. On the canvas, in the Select widget, select an interactive selection tool.
The interactive selection tools from the Select widget
  1. Draw the selection on the Map widget to select the features. In this example, five features are selected.
Five features are selected using the Select widget
  1. In the Select widget, click Actions > Set as Analysis input.
Click Actions and Set as Analysis input in the Select widget
  1. In the Set as Analysis input window, configure the following parameters:
    1. For Select a tool, select the tool from the drop-down menu.
    2. For Select a parameter, select the input parameter.
    3. Click OK.
The Set as Analysis input window
Alternatively, use the Table widget. After selecting the intended features using the Select tool in the Map widget, set the features as the analysis input using the Actions button in the Table widget. Then, repeat Step 8 from the solution above.
Click Actions and Set as Analysis input in the Table widget
The Analysis widget below includes only the selected features from the connected Map widget as the input for the Create Buffers tool.
The Analysis widget includes only the selected features as the input
Article ID: 000039883
Software:
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
