PROBLEM
Feature layer name renamed in an ArcGIS Online web map is not reflected in the map legend in ArcGIS StoryMaps
First Published: September 2, 2022
Last Published: September 2, 2022
When renaming a feature layer in a web map in ArcGIS Online, the changes are not reflected in the map, and consequently, in the legend in ArcGIS StoryMaps.
Renaming a feature layer and displaying the changes in the map legend in a story may be necessary to enable a user-friendly interface for easier navigation and data interpretation.
Cause
This is by design. This behavior is implemented to prevent changes made to a web map from affecting the ArcGIS StoryMaps story.
Solution or Workaround
The following is a workaround to rename the feature layer in the map legend in ArcGIS StoryMaps.
  1. In the story builder, hover over the map to display the toolbar panel at the top and click the Edit button.
Top panel with a set of options with edit button
  1. In the Adjust map appearance window, on the Layers tab, click the feature layer name to rename the layer. In this example, the 'Schools_all' layer is selected and renamed as 'Schools' (image on the right).
All features pane with the Schools_all map layer All features pane with the map layer renamed to Schools
  1. Click Place map to apply the changes.
Place map button at the bottom right corner,  beside the cancel button
  1. Click the Legend icon on the map to view the changes reflected in the map legend (image on the right).
Legend label written as Schools_all Legend label renamed to Schools
Article ID: 000028033
Software:
  • ArcGIS StoryMaps
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
