PROBLEM
When creating a feature in ArcGIS Pro using the dashed stroke symbology, the feature displays misaligned lines and corners with gaps, as shown in the map below.
The Offset value is specified, which introduces gaps at the corners of the feature and causes misaligned dashed lines.
The map shows the feature maintaining the alignment of the dashed stroke symbology.
In ArcGIS Pro, use the Graphic Buffer tool to create a buffered copy of the feature instead of using an offset value. This approach helps smooth out gaps at corners caused by the offset effect in the dashed strokes by adding a small buffer around the graphic element, compensating for misalignments and recreating the offset effect.
The map shows the feature buffered according to the specified offset in ArcGIS Pro.
Article ID: 000034653
Get help from ArcGIS experts
Start chatting now
